RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   voltmeter (https://www.rcuniverse.com/forum/questions-answers-154/11629781-voltmeter.html)
halflight 05-25-2016 04:16 PM
voltmeter
looking for a reliable voltmeter to test NMH receiver battery
that I can plug into switch/charge jack located in the fuse
RBACONS 05-26-2016 01:12 AM
Radio South Pro-ESV Tester
jetmech05 05-26-2016 05:27 AM
What ever you get make sure you load the battery
I use one from hangar 9. I can select 1/2 amp or 1 amp load. How accurate it never gets calibrated. Close enough for government work
warhwk 05-26-2016 07:03 AM
1 Attachment(s)
My favorite loaded battery tester is the Expert V-300. Horizon no longer carries them, but they are usually available new on Ebaay for less than $20. It loads the battery at 300mA and will test both 4 or 5 cell rx packs. It is the most valuable field tool I own. I check the rx batteries before each and every flight. It has saved me at least one plane that dropped a cell between flights.
Greg Wright 05-27-2016 03:23 AM
1 Attachment(s)
Hanger9 Variable load meter.
http://www.rcuniverse.com/forum/atta...mentid=2164373
warhwk 05-27-2016 04:33 AM
The Hanger 9 meter with a 2A load would be great for larger models with digital servos.
Greg Wright 05-27-2016 01:34 PM
It's good for checking any size airplane batteries.
