RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   an Un Cure question here (https://www.rcuniverse.com/forum/questions-answers-154/11638116-un-cure-question-here.html)
the Wasp 04-11-2017 06:37 PM
so after using Un Cure does it evaporate and you can reglue over it ??,, I have a wing that has a broken spar, thought I would just replace the spar if I can reglue after using Un Cure
thanks guys !!
Jim
jetmech05 04-11-2017 07:46 PM
Wouldn't it be better to just glue in doublers. No chance of warping the wing that way
the Wasp 04-11-2017 08:10 PM
1 Attachment(s)
well it's spars are Balsa, and it's a 73" span Classic racing plane with a 35cc MVVS,, this plane "full size and scale" has been known to fold in a wing, I would like to replace at least one Balsa spar with Spruce and Sheer Wed it,, I don't see myself warping it
Jim
jetmech05 04-13-2017 06:04 AM
Anytime you remove the spar you run the risk of warping the wing. A doubler between the ribs will fix the cracked spar. Same as full scale is fixed
JollyPopper 04-13-2017 11:26 AM
But the question of regluing over Un Cure has not been answered. Anyone? Does it evaporate to the point that the balsa can be reworked as new balsa?
the Wasp 04-13-2017 04:20 PM
thank you Jolly Popper
Jim
TomCrump 04-14-2017 04:08 AM
Is "uncure", debonder ?
If so, I have successfully re-glued parts after using it.
Does it make the balsa like new ? No. The debonder dissolves CA. It's still there in a diluted form, but soaked deeper into the balsa.
