Three Blade
Every time the words"3-blade prop"are used someone always jumps in and says it cuts the efficiency of the engine.What does it actually change in the flight of the plane? Is it a great big something or only a slight something? Slower speed, slower engine response or what?I have used a 3-blade and then a 2-blade prop on sport planes and don't see any real difference.Do the nay- sayers have any real experience or only just want to offer their opinion? Most all the electrics use 3 and sometimes 4 blade props.Should not they just fall from the sky?
1 Attachment(s)
The most efficient prop is a slow turning single blader sometimes seen on competition rubber models with limited rubber. Coupe d'Hiver.
In practice for general model use a 2 blade prop is the way to go but using a 3 blade prop although bringing a small performance loss say 3% is generally OK as our setups usually have excess power. More here Attachment 2247356 |
Thanks for the reply! I have heard the comments about loss of performance but have always wondered about the amount. The 3% doesn't seem to be critical so I see no reason not to use 3-blade. They look so good.
Electric motors have most of their torque at the low end so they can turn 3 and 4 blade props better than internal combustion engines. I've always thought it strange that people will significantly overpower their warbirds, put non=scale 2 blade props on them and then run them a half throttle.
Imho
3 blade props allow for more ground clearance, are quieter than the equivalent 2 blade, help slow you down on vertical down lines and on approach.
3-blade
Sounds like a good deal.Slowing down but still being good for landings is an asset.
This has nothing to do with how they preform, but I do like the way they look. I have run a 3 blade on a ST 45 for years never really noticed any loss of performance. I have had to go to 3 and 4 blade props or make landing gear so tall it looks like a clown car bouncing down the runway. With how over powered our planes really are, if they do loose anything, not sure we would even notice it.
Buzz. |
Originally Posted by rgburrill
(Post 12389571)
i had a 3 blade on my old Marie Mustang with the OS 120 4 stroke. The speed difference wasn't even noticeable when I threw a 2 blade on to see if it was faster one time. |
Great! This what I came to believe after trying a 3-blade a time or two but everytime a 3- blade is mentioned someone always says' It will not be as efficient" and so I went back to 2-blade.The 2-blade worked good so I just stuck to it as a matter of cost and availability.
Hi!
I think when fliers say that two blade propellers are "better" they think of high perfomance planes like low winged advanced planes, pylon planes and F3A pattern planes, not the ordinary high winged trainer or warbird. |
4 Attachment(s)
I've been using 3 blade props on IMAC and pattern airplanes for years. They are gaining popularity in pattern.
Originally Posted by speedracerntrixie
(Post 12390783)
Ken. |
Yes, a 3 blade along with the ESC brake can really slow the airplane down. Thinking about that a bit more, I think I have too much brake set and my downlines could be a tad too slow however it's nice to have a fair amount of brake to help slow down for landings. Maybe the next generation ESCs should have Brake rates switchable at the TX.
I have used three blade props for many years and have had good luck. But not all three blade props are the best.
I picked up a FMS P51 elect that used a 4 cell and came with a 4 blade prop. I toyed with others, 2 or 3 blade and different sizes, but the four blade pulled it around very well and better than any other prop I tried. sticksl |
