AEROScout S 1.1
Purchased a new aero scout s 1.1 fuselage after a crash, and had to remove motor, receiver, and other wiring from the crashed one. Forgot to take a photo of the proper configuration before taking apart. Any chance someone could post a picture of the configuration (which wires go where on the receiver? A txt or word doc describing the connections would work also.
It's not hard to figure out.
Take one servo and plug it in wherever you want. Move the sticks until it moves, then write down which surface that channel is supposed to be. It'll only take a few minutes to get it all right. On the motor, if it's brushless, it'll have 3 wires going into it. If you get it all together and the motor turns the wrong way, switch any two wires. |
