RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Uneven weighted wings (https://www.rcuniverse.com/forum/questions-answers-154/11691589-uneven-weighted-wings.html)
Fishgod123 07-05-2021 10:26 AM
Question: is it better to keep a DLG lighter but have wings of uneven weight, or heavier but balanced?
​​​I made some fiberglass DLG wings, and applied more resin to the second wing since I wasn't pleased with the adhesion to the foam core on the first. Without realizing it, I ended up putting way too much with the second wing being 17g heavier than the first. Hoping that I don't have to redo it, am I better off keeping the DLG lighter and unbalanced, or heavier and balanced. Bare in mind it's a 1.5m DLG, with a total weight at 240g
rgburrill 07-06-2021 03:45 AM
That 17 grams is spread over the entire wing. You can add about half the extra weight at the wing tip to get the wings CG balanced.
daveopam 07-06-2021 01:17 PM
I'm not familiar with that air fame but if the fuse in not balance laterally there may be some help there. Last profile I built for example has a 26cc engine off to one side so I mounted the battery in the other wing.
David
