RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   ultra stick 60 (https://www.rcuniverse.com/forum/questions-answers-154/1366041-ultra-stick-60-a.html)
sherm172k 12-20-2003 04:17 PM
ultra stick 60
[font="Courier New"]i am putting together my ultra stick and i just got to the point where i put in the engine. However, i'm using a saito 100 and the slider for the throttle pushrod seems to be on the wrong side of the carb. The pushrod will never be able to reach the slider in the present spot. has anyone else ever had this problem? thanks.p.s. - happy holidays.[/font]
NOVAflier 12-20-2003 09:37 PM
RE: ultra stick 60
The engine should be mounted at a 90 degree angle, meaning that the throttle will be facing up, and looking down at the top of the plane, you will see the side of the Saito. Then, you can rotate the carb 180 degrees, I think there is a small scew on it that holds it and you can rotate it into position.. Let me see if I have a photo..
NOVAflier 12-20-2003 09:43 PM
RE: ultra stick 60
1 Attachment(s)
You can sort of see it here, if you need some close ups, I can get them tomorrow, send me a PM..
Also, I posted a ton of pics in this forum..
[link=http://www.rcuniverse.com/forum/before_I_start_my_H9_Ultrastick%25%25%25%25/m_1347853/tm.htm]H9 US 60 Discussion[/link]
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
