RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Affixing Aluminum To Fiberglass (https://www.rcuniverse.com/forum/questions-answers-154/1366531-affixing-aluminum-fiberglass.html)
Gammaman 12-20-2003 08:59 PM
QUESTION,
BEST WAY TO AFFIX, ATTACH, ALUMINUM TO FIBERGLASS. I HAVE MY THOUGHTS BUT WOULD LIKE TO HEAR OTHERS. THANKS, LON
Walter D 12-20-2003 10:28 PM
RE: Affixing Aluminum To Fiberglass
Goop.
Gammaman 12-20-2003 10:48 PM
THANKS WALTER,
I HAVE SEEN ENOUGH OF YOUR OTHER POSTS TO KNOW THAT YOU ARE NOT JOKING. BUT IS THAT JUST "GOOP" OR IS "GORILLA SNOT" THE SAME THING? I STEPPED IN SOME GOOP ONCE AND I HAVE FIXED MY SHOES WITH GOOP. ARE WE TALKING ABOUT THE SAME THING? THANKS, LON
Walter D 12-20-2003 11:33 PM
It's called Goop and you will find it at any hardware store and most retail stores as well, it comes for different applications, but to me, they are all the same, just marketing hype, the regular one for household use is the one that I use the most, it will stick to anything with a vengeance, because it is heavy and because it works so well, use very little of it, small dabs here and there work very well, an entire surface doesn't need to be treated, test it first so you see how it reacts, spread some with your finger and see how much fun it is to pry it off your skin, no kidding, it's fun! I haven't seen Gorilla's Snot, but I do use Goop to fix the soles of my Sneakers when they start to come unglued.
Flypaper 2 12-21-2003 09:37 AM
I'll go for Goop too. Have a Yellow Cap 10 B with an aluminum fuel tank bracket, servo mounts glued in with Goop. Snapped into the trees at about 60mph. None of the joints came loose. Had to build a new wing. Tough stuff.
Gammaman 12-21-2003 11:57 AM
I AM FINISHING UP THE COWL ON A NWHT GEE BEE Z . IN ORDER TO HAVE A CLEAN, NO SCREWS SHOWING COWL, I MADE AN ALUMINUM 14" RING THAT BOLTS TO THE FIREWALL. I NEED TO NOW ATTACH THE FIBERGLASS COWL TO THAT RING FROM THE INSIDE OF COWL. KINDA WORRIED ABOUT THE VIBRATION ISSUE. THANKS, LON
Flypaper 2 12-21-2003 02:52 PM
Lon;
Goop is a type of rubber cement that won't let go so what you have is an ideal spot for it.
Gammaman 12-21-2003 03:30 PM
Goop it is, just sounds to simple but that's not a bad thing! Hope it holds up to heat and gas! Thanks to all, Lon
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
