RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Looking for a good 3-D prop (https://www.rcuniverse.com/forum/questions-answers-154/1380080-looking-good-3-d-prop.html)
bmgbeetle 12-27-2003 02:20 AM
It's an OS 91 Four Stroke. It's currently mounted on a U-Can-Do, and presently swinging a 16x4 by APC. I run 15 syn fuel, cause it gets so hot down here in FL. Unfortunately it'll only turn it to about 8500. So I wanna try a 15x4, and I wanna go to a wood prop for weight conservation and spool up.
My question is, who makes a good prop, where do I find one and do I seem to be on the right track? I'm shooting for another 1500 max rpm and faster spool up.
Jemo 12-27-2003 09:04 AM
RE: Looking for a good 3-D prop
On my Saito 91:
I have used a 15x4 APC and I also cut one down to 14-1/2x4, I seem to like the cut one best. I haven't tried a 4 pitch wooden prop but I think it would spool up quicker.
I can't remember RPM's but it's really good.
TerrellFlyer 12-27-2003 09:43 AM
That is a high rpm for a 4 stroke,I try to keep mine at the mid to high 7's also I'm using a wide APC on my edge
bmgbeetle 12-27-2003 05:39 PM
Well, when it was on my pattern plane(Swallow), I was using a 14x7, and it turned to 9500. I don't wanna get quite to 10,000, just real close. That seemed to be it's sweet spot. The RPM range is listed at 2,000-12,000. But I don't wanna go quite that far. Mainly it's the spool up. It'll go vertical just fine as it is, but I want better pull out.
Today I was flying, and the engine kept leaning out in hover. This is a sudden issue, no changes were made when it started doing it. It hovers pretty well, but when you go to power out of it, it almost stalls. Now I'm looking into a pump. I was asking around, and I was told that perry makes a pump, powered by the vibration/oscilation of the motor. Heh, I'd never heard of that. I was told it worked, "Alright", but I figure I can either equip this motor with an OS mechanical pump, or, a small electric. Any suggestions?
outssider 12-28-2003 01:50 PM
http://www.ironbaymodelcompany.com/W...Regulator.html
http://www.rcuniverse.com/forum/m_13...tm.htm#1367788
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
