RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   ap.09 running problems (https://www.rcuniverse.com/forum/questions-answers-154/1387685-ap-09-running-problems.html)
Flying Scotsman 70 12-30-2003 03:23 AM
This engine just keeps quitting in flight! When i hold the plane verticle while running has a higher rpm than when it is held horisontal any help please!
Flypaper 2 12-30-2003 12:51 PM
RE: ap.09 running problems
Make sure the tank is as close behind the engine as you can get it. Hold the nose up and set the carb till the engine peaks. back the needle out till you can hear it noticably slow down, then try it. Don't forget, as the fuel level goes down the engine keeps leaning out. The engine should be at peak RPM by the time tank empties. To big of a tank can make the problem worse.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
