ball links setup
1 Attachment(s)
Hey
I want to use ball links on my Funtana but dont know what to get and how to set it up. Here is what I think I need: * [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD914&P=0]Dubro Adjustable Ball Links 4-40 w/Hardware[/link] * [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD905&P=0]Dubro Swivel Ball Link 4-40[/link] * [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEMF9&P=0]Dubro Heavy Duty Control Horn .40-.91[/link] 1. Are those the only things I need for the setup except for the push rods? 2. Should I use the adjustable ball links or the regular heavey duty ball links on the servos? 3. I added a picture the I drew in paint of what I think the setup should look like, can someone please tell me if its right? Thanks |
RE: ball links setup
Well, Im changing my mind about the horns because they are way too expensive.. Im switching to the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD935&P=0]Dubro Control Horns Nylon T-Style[/link]. So do you think I should use the swivel ball links with the nylon horns or a regular clevis?
Thanks |
Good quality clevises are fine. I like the Sullivan Gold or the Du-Bro Safety Lock Kwik Link. I used the control horns that came with the ARF as well. I read where a few people had problems with the stock control horns being brittle but I purposely tried breaking one of them from my package and it wouldn't. Maybe I got different ones, I don't know.
1 Attachment(s)
Here's what I did on my Funtana
Ed, is that the swivel ball link on the control horn or the regular heavey duty one?
Thanks Also, does it matter if I use the regular or swivel ball links on all connections? How should I set it up? Which kind is better? |
