RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   2mm die left hand and right hand needed (https://www.rcuniverse.com/forum/questions-answers-154/1394787-2mm-die-left-hand-right-hand-needed.html)
nexuscrash 01-01-2004 11:07 PM
Modifying some servo linkages for a Kyosho 46VR Helicopter.
The Zeal kit I am trying to retro fix has 2 mm rods that uses both left hand and right hand threads.
Does anyone know of a place that sells both?
I see century heli has a RH die but I cannot find the LH die.
http://www.heli-world.com/Merchant2/...ct_Code=CN2039
Michael
MinnFlyer 01-02-2004 11:35 AM
RE: 2mm die left hand and right hand needed
Do a Google search for "Machine Tools". You'll probably find a few manufacturers that have them.
SpaceCowboy 12-12-2007 01:50 AM
Hi ; The R/H 2MM is the easy one to find. I finally found a L/H 2mm die.
They actually have ones from 1.6mm to 48mm.
They are in England though and pricey, but look like good quality.
2mm L/H = 18.29 pounds 2mm R/H = 9.54 pounds
www.engineering-supplies.com
kdc 12-12-2007 07:23 PM
If you want taps or dies from an English supplier try Tracy Tools www.tracytools.com
They list almost every thread. Left Hand costs 200percent extra. A 2mm die in their last years catalogue costs 3 pounds ( about 6 USdollars ) so a LH would cost about 9 pounds 18 dollars!
You need to specify the pitch as there are 3 pitches at this size.
mikenlapaz 12-22-2007 01:04 AM
MC MASTER-CARR IS WHERE I WOULD START.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
