RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Prop for an OS 1.08 on the CG Extra300 (https://www.rcuniverse.com/forum/questions-answers-154/1416392-prop-os-1-08-cg-extra300.html)
Navy18 01-09-2004 07:16 PM
I am placing an OS 1.08 on my new Goldberg Extra300...... I want to get the best speed and vertical combination without burning out the engine. I like to fly at higher throttle settings and want to get the best combo for this engine. Any suggestions? Thanks.
Azcat59 01-09-2004 07:58 PM
RE: Prop for an OS 1.08 on the CG Extra300
A 15x8 would be my first choice. You might also want to try a 14x10 if you want a little more speed, or a 15x6 for more acceleration. All APC brand. I fly a GB Ultimate Bipe with the ASP 108 using a 14x10 and the performance is very good. We went to a 15x8 on my friend's Ultimate with an OS 108 to slow it down a little for him. Also works well.
Clair
Navy18 01-09-2004 10:41 PM
Thanks AZCAT..... I will try the 15x6 for the breakin and first few flights. I want some high speed passes as well as some acro practice; appreciate it.
nitrous pete 03-07-2004 05:41 PM
I also have a Ultimate GB, And a 108 os , i Use A 14-10 APC , Can u tell me what fuel to use in the 108, What %
I have tried 5 , and 20% , can't decide which to use, I also have 25%
pete
3DFanatic 03-08-2004 01:51 AM
I was using a 16x5 on mine. Turned 9K RPM
RichLockyer 03-08-2004 02:21 AM
Running a 16x6 here. I don't dare fly straight and level for more than a short run at full throttle, has excellent vertical.
I do run a Perry pump driven by case pressure.
