RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   What is Synthetic Fuel? (https://www.rcuniverse.com/forum/questions-answers-154/1418457-what-synthetic-fuel.html)
mR JoLLy 01-10-2004 03:02 PM
While I am aware of what Castor Oil is, does anyone know what a synthetic oil is made up of chemically.
I am interested in this subject as I blend my own fuel and want to study the subject further.
I suspect they are possibly poly glycols of some sort [&:] with a lube additive for corrosion prevention, bit I am currently just guessing.
Anyone got any insider information or can suggest any links. All most welcome!
JoLLy
Stick Jammer 01-10-2004 03:43 PM
RE: What is Synthetic Fuel?
Synthetic oil contains no petroleum products. A totally synthetic fuel contains no Castor as well. If you are looking for a recipe to make synthetic oil, I doubt you'll have the necessary facilities to make your own. If you are simply blending your own fuel, I believe Klotz synthetic 2-cycle oil is used by Sig in their fuels, probably others as well.
mR JoLLy 01-10-2004 05:26 PM
Stick. I am an industrial Chemist which has a slight advantage. ;)
I a simply curious that all you see on the internet are statements about special blends of synthetics oils and additives.
While I am convinced the additives are some form of complexed polymer, I do not want to run any "risks" with my motors. Having some idea will help me identify the chemical family I need to investigate.
Bring it on folks!
Ed Smith 01-11-2004 08:47 AM
Contact Klotz or Union Carbide, both manufacturers of synthetic oils. I am sure they will be very willing to pass on their oil constituents!!
Ed S
mR JoLLy 01-13-2004 02:57 AM
Ed the Manufacturers will not share their formulations that easily.
What I do know is that the base constituent is Poly oxy alkyl (or alkylene) glycol ethers. Think of that next time you get a lung full of exhaust fumes [&:]
Now I know the generic family I am away!
Got the anti ware additive, got the anti oxidant.
Fantastic.
CafeenMan 01-13-2004 03:12 AM
Ed is pulling your chain, Mr. Jolly. Good luck with your new line of fuels. :)
mR JoLLy 01-13-2004 03:15 AM
I am just trying to be polite :eek:
CafeenMan 01-13-2004 03:22 AM
ORIGINAL: mR JoLLy
You could get banned for that. :)
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
