HOW FAST IS THIS PLANE?
HOW FAST IS THE HANGER NINE MUSTANG WITH A SAITO 91 AT FULL THROTTLE MINUS ABOUT 300 TO 500 HUNDRED RPM'S[60-SIZE]..?
RE: HOW FAST IS THIS PLANE?
What prop? how's it ballanced? What pilot is behind the sticks? Wheels up or down?
It'll break 120 in level flight set up correctly or speed runs. Take-off will be a beast with the speed prop. |
ORIGINAL: SIR CRASH-A-LOT! HOW FAST IS THE HANGER NINE MUSTANG WITH A SAITO 91 AT FULL THROTTLE MINUS ABOUT 300 TO 500 HUNDRED RPM'S[60-SIZE]..? |
ORIGINAL: FHHuber What prop? how's it ballanced? What pilot is behind the sticks? Wheels up or down? It'll break 120 in level flight set up correctly or speed runs. Take-off will be a beast with the speed prop. |
Why do you want it to go so fast?!
why not?"to each his own",right?:D
ORIGINAL: dr_wogz Why do you want it to go so fast?! BTW, multi-cylinder engines will not be as fast as single-cylinder engines. |
Then why not go with a Reno racer kit in teh first place!! [X(]:D
| All times are GMT -8. The time now is 02:07 AM. |
