RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Help with a manual pump (https://www.rcuniverse.com/forum/questions-answers-154/1554660-help-manual-pump.html)
hardlanding7 02-22-2004 09:21 PM
1 Attachment(s)
I took my fuel pump apart, which, is a very bad idea, and now I can't get it back together. Does anyone know where the spare gear shown in the pictures goes or have a schematic?
FHHuber 02-22-2004 11:32 PM
RE: Help with a manual pump
Its going to stack on the same shaft as the center gear.
You are goingto have to test which gear really goes where... and which way is up on the different gears. The only 2 that I can assume are in correct position at ths time are the ones attached to the handle and the one that is on the pump itself. the one that is on the middle shaft is on incorrectly.
ifixairplanes 02-23-2004 11:35 AM
if it aint broke, take it apart till it is!!!
sean
