Balanced??
1 Attachment(s)
This is my first mid-wing to balance. ...this looks good what do you guys think?
RE: Balanced??
Too far forward:D
RE: Balanced??
you mean the picture or the CG? The fuse looks level to me...is that what i'm supposed to be looking for?
RE: Balanced??
I was joking(notice the little smile)....that is about the best job I have ever seen(I thought you were showing off)...as long as your cg is where you want it..
RE: Balanced??
OH :-D thanks...i strive for perfection
RE: Balanced??
Yes. As long as the CG machine is set on the CG point then the plane is sitting as it should for good balance.
Dennis- |
RE: Balanced??
sure is sitting level... sure you didn't prop the rudder up? :)
Yep... its balancing on whatever point yo set the CG machine on... Can't tll by the pic where that is related to wing chord... (looks a touch forward to me... but it is a bad angle for judging that.) |
| All times are GMT -8. The time now is 10:27 AM. |
