RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Digital tachometer Lighting Need Help (https://www.rcuniverse.com/forum/questions-answers-154/1587650-digital-tachometer-lighting-need-help.html)
propjobbill 03-03-2004 07:13 PM
I would like to be able to use my digital tachometer in my building. If I use florescent light or regular incandescent lighting the tech read the light frequency usually 3600. Is there some form of indoor light that will work well?
Bumstead 03-04-2004 07:12 AM
RE: Digital tachometer Lighting Need Help
Most digital tachs read light pulses/time=frequency=RPM
They will all react to the strongest pulsed source.
If you have flourecent lights, they will read 3600 in the US
You need a steady state light for the prop to interrupt, like the sun.
I haven't tried them indoors but you may try one of those very bright LED's flashlights
The light source is continuous and might trigger your tach properly.
rajul 03-04-2004 07:52 AM
ORIGINAL: propjobbill
What do you plan to use the tach for ?
bentgear 03-04-2004 08:00 AM
Any good strong REGULAR flashlight will work. Not sure on the LED flashlight because I think the circuit used to drive them pulses the LED.
Did this years ago for a down and dirty dyno for rc car motors. Worked pretty good.
Ed M.
propjobbill 03-04-2004 09:49 PM
I tried a flashlight and it works, Thanks for the information
:D
