RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Balancing a plane (https://www.rcuniverse.com/forum/questions-answers-154/1615916-balancing-plane.html)
ray c. 03-11-2004 09:58 PM
Balancing a plane
I am finishing my first build. It is a world models low wing sky raider. I am trying to balance it now. It is the first time I have ever tried to balance a plane. When I balance it laterally it seems like it would take a lot of weight to overcome the muffler. Is this normal? I don't know how much it would take to balance since I haven't found an outlet for stick on lead weights.
Any help would be greatly appreciated.
Ray
MajorTomski 03-11-2004 10:07 PM
RE: Balancing a plane
Ray, by balancing laterally you are hanging the airplane by string tied to the propeller shaft and the fin, right? And you have the strings moved so that they're on the centerline of the airplane? If it is tilting to wards the muffler, let's make sure that the muffler is the problem first. Take off the muffler and see what happens. if the plane still tilts the same way it's not just the muff. Instead of stick on weights get some small gage buckshot and drill a hole in the solid wing tip. add the shot to the wing tip till the plane balances with the muffler on then fill the hole with glue. Once dry cover the hole with a monocoat patch.
HTH
Tom
volkan 03-12-2004 02:42 AM
hold up the plane inverted, get 1 person to hold one wing, and you hold the other, place your fingers on 1/3 (or wat ever the instructions say) of the wing chord, and add weights if nessary, try to make it more nose heavy, than tail heavy. but don't go streight for weights, alter batery positions first
ray c. 03-12-2004 09:06 AM
Major
Thanks for the advice. One more question. Should the plane be inverted when balancing laterally or to find the CG? Also if the muffler is the problem should I add that much weight to overcome it?
Thanks again
Kaos Rulz 03-12-2004 09:17 AM
Inverted for both fore/aft, and lateral because it's a low wing. High wings are just the opposite.
Geistware 03-12-2004 09:44 AM
Upside down or right side up will not make any difference in the balance of the plane.
What may make a difference is the ease of supporting the plane in the balancing position.
YOu may need to have the wheels up to use your balancing tool.
MinnFlyer 03-12-2004 11:12 AM
And don't worry about removing the muffler. What's the point? You're not going to remove in flight, right?
Here are some good tips on Balancing:
http://www.rcuniverse.com/magazine/a...?article_id=84
