H9 1.20 CAP 232, SAITO 150 or 180?
I recently aquired a Hangar 9 CAP 232 1.20. It is the Matt Chapman version and i'm wondering which engine to put in it, the SAITO 150 or 180? Any feedback is welcome. Thanks.
RE: H9 1.20 CAP 232, SAITO 150 or 180?
If you do a search you will find lots of info on this plane here on RCU... Bottom line is most are very happy with the 1.80... With the 1.80 it will likely come out a little tail heavy so don't start out tail mounting the elevator servos. Wait to figure out where to put the servos until you know where the CG is going to end up...
the 180 came out after the 150 and more-or-less has made the 150 obsolete
just like the 100 did to the 91 |
