Servo horn screw type and size?
what size and type of servo horn screw goes on hobbico cs-65, cs71? Where can I get one?
RE: Servo horn screw type and size?
I'm not sure about the screw size, but if you email Hobbico, maybe they can provide the answer.
[email protected] Eric |
most standard servos use a #4 sheet metal screw
jerry |
Yes, they are usually about 8mm long. But, the Hitec company now uses 10 mm long screws for some of their newer servos to prevent the shafts from breaking under higher stresses.
Patriot |
Look for a friend that has some Futaba gear. It will likely be the same screw.
