RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Epoxy question (https://www.rcuniverse.com/forum/questions-answers-154/2069846-epoxy-question.html)
crazystix 08-09-2004 08:22 PM
Epoxy question
Will thinning epoxy w/ alcohol slow the cure rate? I'm trying to put a horiz. stab on & only have 5 min. epoxy, which doesn't give me enough time to make sure it's on straight (this time). thanx
DBCherry 08-09-2004 08:34 PM
RE: Epoxy question
No, thinning it won't slow the cure rate. Wait and buy some 30 minute.
Dennis-
crazystix 08-09-2004 08:41 PM
RE: Epoxy question
bummer.[&o] I hate waiting. tHEN AGAIN, i REALLY HATE WHEN i PULL UP AND GET A ROLL TO THE RIGHT ALONG WITH IT (damn caps lock:D)
crazystix 08-09-2004 08:55 PM
RE: Epoxy question
Had to go for it anyway.Turns out the third time IS the charm! :D
SST 08-09-2004 09:31 PM
RE: Epoxy question
Yeah Geez, I've been using 5-minute on everything for years. Bought my first 30-minute ever this year, and hate it.
Campy 08-10-2004 11:20 AM
RE: Epoxy question
ORIGINAL: crazystix
No. You need to get some 30 minute epoxy. The 30 minute epoxy is less brittle and typically stronger than the 5 minute.
Heavy Date 08-10-2004 11:44 AM
RE: Epoxy question
Campy hit it on the head. The longer the cure time the stronger the joint. I don't use 5 min for anything on a model. Too brittle and weak. I use the 30 min for general stuff and 2 hour for anything like wing brace joints and such.
Hans
Rodney 08-10-2004 12:41 PM
RE: Epoxy question
Do not trust 5 minute for what you are doing, very poor and much weaker than the slower cures. Use at least 30 minute epoxy.
bentgear 08-10-2004 01:01 PM
RE: Epoxy question
While it may be weaker it is still strronger that any of the wood in the plane. The two things that 30 minute epoxy gives you are working time and since it takes longer to harden it should work into the wood a little better for a stronger bond. To me, its just makes sense to use 30 minue epoxy on wing joints and tails.
Ed M.
jaka 08-10-2004 03:27 PM
RE: Epoxy question
Hi!
30min Epoxy!!!!???
When there is Flash Ca glue!!??
Never uses epoxy..only Ca glue...and kicker of course.....much easier and faster than epoxy.!
Regards!
Jan K
Sweden
