Cowl problem
I am building a GP Super Decathlon. When I was trying to smoothen the holes I opened for the engine the sanding tool touched the surface and made a small dent. Is there a way that I can fill it up before spray painting?
RE: Cowl problem
ORIGINAL: SERAFIM I am building a GP Super Decathlon. When I was trying to smoothen the holes I opened for the engine the sanding tool touched the surface and made a small dent. Is there a way that I can fill it up before spray painting? Put in on, let dry overnight and sand with 150, then 220 paper. Then prime and paint. If you need a "backing" to partially close the hole, use a piece of 2 oz fiberglass cloth on the inside of the cowl and adhere it with THIN CA. |
| All times are GMT -8. The time now is 03:45 AM. |
