ME-109 House of Balsa - CG and throws
Hi,
I picked up a House of Balsa ME-109 Kit K-08 on the weekend with no radio or plans. I searched the web for the manual, but no luck. Can anyone help me with the CG location and what the control surface movements are? Thanks for your help. Wayne Miller |
RE: ME-109 House of Balsa - CG and throws
The c.g. is at or just forward of the spar.
Control throws with a normal arm on the servo and a normal control horn (1/2A) at the surface can use the end holes on each arm. You don't need a lot of surface motion on these tiny airplanes. |
Hi Tall Paul,
Thanks for the information. I was wondering if I could something a little more specific, mainly because I know that different makes of servos have different amount of travel. I'm hoping someone can tell me how much up and down movement I should use for elevator and aileron. Thanks for your help. Fly4Fun, Wayne Miller |
1 Attachment(s)
Measuring mine, I have 3/16" on the ailerons, 5/16" on the elevator.
It's a sloper, not powered. |
Hi Tall Paul,
Thanks for taking the time to measure the throws for me, I greatly appreciate it. This one is powered with a .15 OS Max and the previous owner said it flew very well, but I should back off on the power for a while. The only documentation I have is the ad on the House of Balsa web site, it states a TD .051 - .10 for power. I'll have to read up on slope soaring, I'm not sure how it is done. Fly4Fun, Wayne Miller |
1 Attachment(s)
The House of Balsa "scale" kits, in either size are not beginners airplanes, they demand a lot of attention for takeoffs and landings when they're powered. (P-51, Me-109, T-6)
Taking off too soon, before the plane has really reached a good flying speed results in a tip-stall and snap roll. However, the ground handling is relatively poor especially without a steerable tail wheel, so the direction of takeoff can be random once the plane is released. On landings, if it's slowed down, it will tip-stall. These things need to be flown fast. Takeoffs are best performed with a high wind! The wind makes the vertical surface more effective early in the takeoff run so the plane will track somewhat straight.. . For sloping OTOH, they're ideal, as there's no heavy motor or landing gear to carry around. And they look really neat! The T-6 uses an K&B 28, also an OS 25... very good performer.. The P-51D,and the F5B (P-51 with a camera, which this does have!) are the 44" span kits, the red/yellow P-51D is the "1/12th scale" kit, which uses the same fuselage and wing as the Me-109... |
Hi Tall Paul,
I fly off a grass field, so typically I have to hand launch my smaller planes, both glow and electric. Since I fly Mode 1, hand launchin is not normally a problem as long as I'm careful and know a little of the plane's flying characteristics. The combat "fun plane" I fly, and my electro streak, have no landing gear and so I normally hand launch them and just grease them in on the grass. However, the airframe on the 109 looks a little fragile, so I plan to leave the gear on hand launch with just a little nose down and "try" to land carefully. The ME-109 only has 3 channels (no rudder). Any more suggestions or advise would be greatly appreciated. Thanks for your help. Fly4Fun Wayne Miller |
Wayne, for handlaunching, and more so for landing on grass, landing gear is a handicap. It catches on the grass and turns the plane over. Greasing it on is the way to land.
ps. if you can fly an ElectroStreak, you can fly anything! :) |
