Weeder convertion
I have a homelite SX- 135 Bandit , the engine runs real good , What plane would be good for this engine? Where do I get an conversion kit ( to add a prop) and what size prop should I run.Also when you convert one of these engines do you use the pull start or electric start?
Thanks Scott |
Weeder convertion
there are two sites I know of that cover this
1. http://www.carrprecision.com/Pages/prod02.htm they also have a list of planes that will work. the second is http://jagengines.com/4stroke.htm hope this helps |
Weeder convertion
You can also bring the engine to your local machine shop and ask for an estimate.
| All times are GMT -8. The time now is 04:41 PM. |
