RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Does this look a good setup? (https://www.rcuniverse.com/forum/questions-answers-154/2469512-does-look-good-setup.html)
высшее одно 12-26-2004 10:25 AM
http://www2.towerhobbies.com/cgi-bin...&I=LXDUL8&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXAKL9&P=ML
five of http://www2.towerhobbies.com/cgi-bin...&I=LXVW07&P=ML
one http://www2.towerhobbies.com/cgi-bin...&I=LXDTB3&P=ML
http://www2.towerhobbies.com/cgi-bin...?&I=LXBY46&P=0
I have the Futaba 6EAX already, and I plan on picking the extensions up at my LHS
CrashBurn69 12-26-2004 10:32 AM
RE: Does this look a good setup?
That will work fine, but, if I was going to buy and 61, I would go ahead and get a 91 and put in it. Either way, just beef up the fire wall a little bit. I guy at my field has an OS 91 in his, but he runs it without a cowl.
MinnFlyer 12-26-2004 10:40 AM
Better yet, get a 70ish 4-stroke
высшее одно 12-26-2004 10:42 AM
they all cost more money, and this is already a little bit over my buget...
Campy 12-26-2004 01:48 PM
You will need to beef up a couple of areas.
The stock firewall is butt glued to the fuselage sides with hot glue. Use some tri stock and 30 minute epoxy to beef the firewall up, especially if you are going to use a larger engine.
The fuselage is weak where the main wing fits in. One hard landing and it will crack. You will need to beef up this area also.
The U-Can-Do is a great flying plane. I don't think you will be disappointed with the plane.
высшее одно 12-26-2004 05:13 PM
thanks for the advise
Should I put the tri stock in the front, or behind? (if I can reach in)
carrellh 12-26-2004 10:59 PM
1 Attachment(s)
Behind. One flat needs to contact the firewall and one needs to contact the fuselage side, top, bottom; wherever you can get it to fit.
высшее одно 12-27-2004 02:11 PM
How should I renforce the fuse? Also, what should I use?
