RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   L.E. (https://www.rcuniverse.com/forum/questions-answers-154/2688869-l-e.html)
RobT 02-22-2005 07:55 PM
L.E.
What is the best way to get the leading edges to have the same radius?
Rob
khodges 02-22-2005 08:34 PM
RE: L.E.
I sand the first one to whatever is required, and then make a template of the profile, and sand the second one, stopping frequently to fit the template and see where the second LE is compared to the first one. It takes a bit longer on the second LE, but you'll get an exact match. Be sure to measure along the full length.
Montague 02-23-2005 12:34 PM
RE: L.E.
A long, straight sanding bar helps a lot.
How accurate you need to be depends a lot on the airplane as well. Believe it or not, most sport planes are more than fine just using the ole mark 1 mod 0 eyeball (or mod 1 for those with the laser job done :)).
The template thing is the way to go if you want it perfect.
DBCherry 02-23-2005 06:53 PM
RE: L.E.
I agree with the template idea, except I make a template from the plan first and use it one both leading edges. ;)
Dennis-
RobT 02-24-2005 08:38 AM
RE: L.E.
What if the plan only gives the cross section at the root?
Rob
DamonTX 02-24-2005 09:45 AM
RE: L.E.
I did the eyeball method for years until I tried something new with my current project. I took a 3/8 scrap of MDF and made two templates of the leading edge from a cross section of the plan. Took the templates and tacked them onto each end of the wing then sanded it with a long bar sander. In the end it was dead on and maybe a little quicker than the old method.
