RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Nose Wheel Steering Setup (https://www.rcuniverse.com/forum/questions-answers-154/2832293-nose-wheel-steering-setup.html)
FighterBird873 04-01-2005 05:59 PM
What kind of range of motion should I get from a nose wheel? I can get it to deflect about 25 degrees left and right. That seems like plenty for tracking the runway center line, but will that be enough to taxi around? Its a tricycle gear, 40 size trainer.
birdnest 04-01-2005 06:20 PM
RE: Nose Wheel Steering Setup
it takes very little deflection to steer the plane around. If you have a total arc of 25 degrees from full left to full right, that is probably enough.
peter
Rodney 04-02-2005 09:38 AM
Do not exceed 10 degrees or you will have trouble when trying to taxi, You can get by nicely with about 5 degrees.
Kaos Rulz 04-04-2005 06:15 AM
That's an awful lot of travel. I'd recommend you cut that in half for the first flights. It doesn't take much nose wheel deflection to taxi around.
