Help..need servo .. advice
I have an aerobird extreme with a jittery ( and stripped gears? ) servo. It seems to have multiple wire connections soldered directly to receiver board . I can replace and solder, but I cannot find a source for a replacement servo.
Anybody know where I can get replacement servos?? |
RE: Help..need servo .. advice
I don't beleive there is a direct replacement servo...
You may need to just get a new fuselage.... Unless you can modify something...... Wait to hear from others though |
New fuselage is about $45. Includes motor, receiver, ESC, servos all mounted in new fuselage. Add tail, wing and batttery and you are good to go. Order same channel as current plane and you radio will work fine with it.
Or see if someone here has an old Aerobird they no longer want. Maybe they'll send you the needed parts. :D
Dennis- |
| All times are GMT -8. The time now is 06:00 PM. |
