Robart pump
Hello,
I have just busted two Robart air pumps. These are the hand held pumps with a gauge used to fill the retract system. It's seems that the one way valve is the culprit. The valve breaks and lets the air out of the system. Has anyone else had this problem? How was it fixed ? tom |
RE: Robart pump
By buying a $40.00 chordless rechargeable air compressor at home depot or walmart. Never have a problem with those dumb robart pumps again ;)
RE: Robart pump
go to a bycile shop and get a good bike mounted hand pump
RE: Robart pump
I use a foot pump that I bought at Walmart. The pump has a guage built on and provides 120 PSI.
RE: Robart pump
Those tire pumps you plug into your cigarette lighter work well too.
| All times are GMT -8. The time now is 09:55 AM. |
