RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   MODELTECH MAGIC SPECS (https://www.rcuniverse.com/forum/questions-answers-154/3087530-modeltech-magic-specs.html)
flyhi 06-18-2005 11:58 PM
Got one at a swap meet, would anyone be so kind as to tell me the hi, low rates and cg? many thanks. p.s. got a TT 46 Pro in it for now, but haven't flown it, waiting on cg.
carrellh 06-19-2005 12:40 AM
RE: MODELTECH MAGIC SPECS
http://www2.towerhobbies.com/cgi-bin...?&I=LXBGB0&P=0
SPECS: Wingspan: 52" (1320mm)
Wing Area: 725 sq in
Weight: 3.5 lb
Wing Chord: 14" (355.6mm)
Airfoil: Semi-Symmetrical High-Wing
Center of Gravity: 4.52" (115mm) Back from the wing's leading edge
before engine is mounted. ( See manufacturer instructions)
Control Throws- Low Rate High Rate
Ailerons: Up & Down 1" (25mm) 1.40" (35mm)
Elevator: Up & Down 1" (25mm) 1.40" (35mm)
Rudder: Right & Left 3.14 (80mm) 4.33" (110mm)
flyhi 06-19-2005 04:45 PM
Didn't know who made it and should'a checked this out myself. However, this hobby is unbelievable for people going out of their way to help. Info much appreciated, thanks carrellh.
