gws zero
I have the gws zero eps 300c also the gws reciever.. the battery is 600mah 8.4 volt 7-cell. I would like to use the electronics in another project. The difference is.... the powerplant of the new aircraft is the stock fan unit from kyoshi t-33 runs on 6 cell 7.2 volt 1600 mah. can i interchange the equipment and if so do I rewire the motor to eccept the 7 cell or do I rewire the electronics to accept the 6-cell. would appreciate any help.
thanks |
| All times are GMT -8. The time now is 12:35 AM. |
