RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Servo Question, Input requested (https://www.rcuniverse.com/forum/questions-answers-154/3566128-servo-question-input-requested.html)
thinairflyer 11-18-2005 08:33 PM
All the specs are very similar on the Futaba S148, S3003, S3004 and the Hitec HS-425BB. The S148 is called a Precision servo while the S3003 is called a Standard servo, yet the specs are essentially identical. Same specs essentially for the S3004 and the HS-425BB.
I realize the BB servos should be a little better under load, but would appreciate your input using these models as I plan to buy some flight packs pretty soon.
Tall Paul 11-18-2005 08:47 PM
RE: Servo Question, Input requested
Go by the specs. The names are just foo-foo.
redfox435cat 11-19-2005 12:12 AM
open up the servo and look at the pot, don't recommend it if you haven't done it before you'll probably ruin ther servo. there you will find your differance. basically a higher grade pot means better centering and position sensing, also becuase of the cleaner resistance on the pot the gain on the amp is turned up a hair meaning it has a bigger ear to listen and make position changes. but go ahead and trust those specs:eek:
you'll probably never notice the differance since it's minute but is there
