cyl. head purchase
Where would be the best place to purchase a new cyl. head for a TT 91 4 stroke and a Magnum 91 2 stroke?
Thanks, Larry |
RE: cyl. head purchase
Trying to find parts for a Thunder Tiger is like trying to pass a basketball out your colon. GOOD LUCK!! Typically, provided by Ace Hobby--but good luck getting ANYTHING out of them.
A side note: I tore the cylinder head off a TT .91 once. Was trying to do an inverted pass down the runway and go under the tape that was strung across the runway on a couple volleyball poles. (Limbo). I tore the head to kibbles and bits. Nothing salvagable. It was $175 for a complete cylinder head. Valves, rocker arms, valve cover--the whole complete head. Shoot!! You can buy a NIB engine for $200. Here's that link to your TT .91: http://www.acehobby.com/ace/TTR9801.htm Magnum parts can be found here: http://globalservices.globalhobby.com/part/21097001.asp Or, if that won't take you directly to the Magnum parts page--then go here and wade through the site untill you find parts support and Magnum engines: www.globalhobby.com |
This guy sells Thunder Tiger parts. Click on the link. It has his telephone number.
http://www.paulsmodelsupply.com/ This guy sells a lot of Thunder Tigers. He got all the parts my friend needed when he dropped a valve in his 91. http://www.hodgeshobbies.com/ Enjoy, Jim |
