sterling stearman pt17
hi i have a pt 17 stearman by sterling and looking for parts,i need the wings or if anyone can tell me were to get them from.thanks mike
RE: sterling stearman pt17
Mike, your best bet is to try to locate a set of plans and build the wing. May be almost as hard as finding a wing. But at least it gives you 2 shots at it! I have a Sterling Gullwing Stinson kit that I have hoarded for about 30 years, and am just now getting in a position to build it!! Lee Robinson W. Palm Beach, Florida
You can replace the original wood wing with a foam wing. http://www.dbalsa.com/global-cgi-bin...pha_search.cgi Or you can build a new wood wing from lazer cut parts. This guy may be able to set you up. http://www.mybloo.com/coosbay/laser/beaver.htm |
I just finished my sterling stearman and have 8 flights on it now....The plane is a dream to fly that was one of the best flying stearman kits I ever built I have built 3 in the past 25 years...kits are getting hard to find..my recent kit was found in a garage in chicago. it was there for the past 20 years....any comments,,questions,,I would be glad to furnish...RCPILOT78
I was informed a good year ago or so that someone is reproducing the large radio version of the Sterling kit. There had been a couple versions offered by Sterling in different sizes.
Go to: http://home.mindspring.com/~jeff.coo...els/index.html And contact Jeff for information as to just who is doing this. for it is not I, as the note above indicates. Wm. |
I'd sure like to see a kit of this plane done again with the advantages of modern laser cutting, accessory molding, and decent light wood. I've got an original kit NIB that I've been holding on to for years, not wanting to build it because the wood is so heavy. I've had to settle for the GP Stearman as the closest modern equivalent version.
If anyone finds out if a re-kit is in the offing, be sure to post here. Rick |
hi rick do u have a pt 17 for sale, if so let me know i have some one who would like to buy one. please let me know . thanks mike
Mine's not for sale. It has increased in value (what I have seen them sell for) three times since I bought it. I figure it will double again in value in about another ten years--then I'll sell it. :D
Rick |
