solartex not sticking
I am using solartex to cover a wing on a citabria pro. I am putting on the starburst stripes and I have one section that wont adhere. I don't have enough to cut a new piece. What can I use to bond solartex to solartex.? Thanks, Willie
RE: solartex not sticking
Did you take the backing off the piece you are working with ????
I haven't worked with Solartex in years but this might be worth a try and it shouldn't hurt if it doesn't work. Use the windex method !! Spray windex on the area then put the trim down and squeegie most of the moisture out from under the trim then just let it dry a couple days. If it holds ok go back over the edges with clear finger nail polish. GOOD LUCK. ENJOY !!! RED |
ORIGINAL: willie45 What can I use to bond solartex to solartex.? Thanks, Willie |
