RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Engine question? (https://www.rcuniverse.com/forum/questions-answers-154/4128263-engine-question.html)
tfarmer96 04-05-2006 02:18 PM
Engine question?
I just put a new Tiger 75 ringed in my tiger 60 (how cute??) any way is there another muffler i can get for it? The one that comes on it is the size of a 3 liter coke bottle and is heavy as a brick. I have run about 1/2 gallon of fuel though it and its great. It makes good power tunes easy and seems to be able to fly the wings off my tiger 60.
campbec 04-05-2006 03:55 PM
RE: Engine question?
Hi tfarmer96,
I have the same motor in my CG Super Chipmunk and I'm more than please with its; performance. STs are very forgiving of non-stndard mufflers and there are a huge variety of after market types such as Slimline out there or you might even consider a tuned pipe. I'm certain you will find you have more than adequate power with the standard setup.:D
Cheers,
Colin
Campy 04-05-2006 04:03 PM
If all else fails in finding an aftermarket muffler, measure the distance between the muffler bolt holes AND the length/width of the exhaust opening. Then check the mufflers at the hobby shop. Many engines are OS clones as far as exhaust sizes.
Hope this helps.
tfarmer96 04-05-2006 06:42 PM
i guess what i need is just a header. i have one but i cant find bolts long enough to make it all the way though the block so i can put nuts on it. I need some exhaust bolts that are about 2 1/2 in long.
fledermaus 04-05-2006 09:49 PM
All the Super Tigres come with enormous mufflers. Bisson makes a nice Pitts-style muffler for the ST-G75, as does Slimline. The Bisson is bigger than the Slimline but no problem to fit it into any plane that the G-75 fits.
Campy 04-06-2006 07:50 AM
ORIGINAL: tfarmer96
Muffler bolts are USUALLY 3mm. Get a 3' length of 3mm ALL THREADED rod and some 3 mm nuts. Double nut one end and solder the nuts together. Cut a slot IN THE TOP NUT ONLY. Cut the rod to the length you need - custom muffler bolts. A 3' length of SS 3mm rod costs about $6 - $7 - enough to do many muffler bolts.
tfarmer96 04-06-2006 08:16 AM
ok i thought they had to be grade 8 bolts.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
