Cleaning after flight
What is the best cleaner to get oil off your plane after flight? I currently use windex, what in your opinion works the best? Do you have any "special" mixes that you use?
Thanks |
RE: Cleaning after flight
If you do a search you will find that this has been discussed many times. For example, see http://www.rcuniverse.com/forum/m_40...tm.htm#4039171
I was using a citrus 409 or something like that. It worked okay but I found that when added a little bit of dish washing soap it really cleaned much better and leaves the planes shiny. [8D]
I use 91% isopropyl alcohol purchased off the shelf at Walgreens.
We're supposed to CLEAN them??
what ever your preference for cleaners is. I buy a gallon of simple green. makes about 40 gals of cleaner mix it with distilled water. twice a year I'll wax the plane with usually Dupont car wax
