RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Looking for 22AWG Battery wire (https://www.rcuniverse.com/forum/questions-answers-154/4155799-looking-22awg-battery-wire.html)
Bidule 04-12-2006 08:10 AM
Hello guys
I have many planes and this winter, after cycling my packs, i realized that 3 of my Battery packs rated @1100mah were bellow 500mah so i put them in the garbage. I now want to build my own battery pack, so i am looking for the wire. I want some Heavy duty Wire black/white bonded like 22AWG or 24 AWG but in bulk quantity. I want to buy a 50 or 100 Feet roll. All i found is sold in 24inch or 48inch length. I already got the connectors, pins and the crimper, all i need is the wire. I am pretty sure someone know where to get this.
Thanks a lot for any help
2slow2matter 04-12-2006 09:31 AM
RE: Looking for 22AWG Battery wire
Go to radio shak. They sell stranded wire in both of those sizes--it will come in a package of three rolls--one roll red, one black, and one green. They are 50 feet each, and the whole package is around 5 bucks.
You wanted bonded wire? Simple--take your red and black wire completely off of the spool. Chuck one end up in a cordless drill, and have someone hold the other end. Spin away--the wire will coil up nice and tight, and it will be "bonded." Not a flat bond, but good enough. A lot of battery manufacturers simply twist their Pos and Neg wires together anyway! This is how I make all of my servo extensions...
2slow2matter 04-12-2006 09:33 AM
Another idea if you truly want flat bonded wire is to go with speaker wire. There is a lot of speaker wire out there in those sizes. You might not get red and black together, but you can get copper and silver, or (at the very least) one wire will have a black stripe, or positive sign, or something indicating some sort of polarity.
Meschmidt 04-12-2006 07:55 PM
Radio shack also sells 3 wire intercom wire that is 24 guage stranded. Color coded red,green, and yellow wrapped in a flexible plastic sleeve. Comes in 50, 150, and 500 ft rolls. Perfect for any type of servo extensions, battery packs, or any other radio electrical as long it doesn't draw more than 1 1/2 amps per lead. Paul
Weasel Keeper 04-13-2006 07:34 AM
ServoCity has 20 & 22 gauge servo wire in bulk. [link=http://www.servocity.com/html/servo_wire__bulk_.html]Servo Wire[/link]
red head 04-13-2006 04:21 PM
Most auto parts stores probably have it or can order it for you. ENJOY !!! RED
Bidule 04-16-2006 10:19 PM
Hey thank you everybody for all your inputs.
Weasel Keeper your the man, that's exactly what i was looking for !
I will just remove the yellow wire and it will be perfect.
I can't believe i spend a whole day looking for this.
Thanks ! :D
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
