Fuel Regulator
Has anyone used the Iron Bay fuel regulator. Any problems or issues I should be aware off
RE: Fuel Regulator
I have two of them installed in a Cessna UC-78. The tanks are in the wing root and thus the fuel has a long way to go to the engines. The only problems that I had were minor: First, I used large size fuel tubling for the fuel feed from the tanks to the regulator because the nipple is so large----didn't work, switched to regular size and the problem was cured. Second, one of the check valves leaked and thus the tank would not pressurize. Cured that problem by getting two valves that come with YS engines at my hobby shop. Otherwise the regulators work great. Regards.
