RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Hovering (https://www.rcuniverse.com/forum/questions-answers-154/442347-hovering.html)
OIL CAN DAN 12-27-2002 10:16 PM
Hovering
I was wondering if there is some kind of training gear like the ones on helicopters or any instruction booklets on learning to hover. I can hold them motionless into a 10 to 15 mph wind but with no wind I'm shot, also do certain planes easier to learn on than a funfly or a tower uproar? Any advice?
For God giveth and the ground taketh away!!!
DIPSY 12-28-2002 12:27 AM
Hovering
A heading lock gyro !
OIL CAN DAN 12-28-2002 01:08 AM
Hovering
With the gyro, would I be able to eventually wein off of it or are you stuck to using it all the time.?
FunK 12-28-2002 01:25 AM
Hovering
You can use a gyro if you like but from what I have gathered from the 3-D crowd around here, you should experiment first.
What kind of plane is it?
Do you have dual rates?
What is the problem when you hover? Does it want to drop a wing, stall, not enough power, etc.
Where is your Center Of Gravity set? Is it nose/tail heavy?
Actually, if you want to learn to hover and have specific wuestions, you may want to just ask this in the 3D forum. Those guys hover all the time.....
OIL CAN DAN 12-28-2002 02:38 AM
Hovering
Thank You FunK, I am relatively new to this forum and didn"t know about the 3D forum. I will post over there. Dan
FunK 12-28-2002 02:52 AM
Hovering
I'm new here too my friend. Nothing to worry about. As a matter of fact there is an active "hovering" thread there right now.
Let me know if you find the correct forum....
FunK
OIL CAN DAN 12-28-2002 02:59 AM
Hovering
Just was over there looking and its just what I was looking for. Wow! What a forum!!!!!!!!! Thanks again!
