RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   GP ultimate bipe (https://www.rcuniverse.com/forum/questions-answers-154/445904-gp-ultimate-bipe.html)
Mi Nan 12-29-2002 03:25 PM
GP ultimate bipe
My friend bought my an ultimate bipe kit for christmas,he thought it would look nice on floats. We don't have a field near by so we do all of our flying off of a near by lake. I have a GP super sportster on GP floats and it flys awesome. I posted this on the rc news group and the consensus was a forty size engine wouldn't be enough to fly it. Are these kits usually tail heavy requireing nose wieght to balance? Could I get away with a 60 size two stroke on it? I really don't want to deal with learning how to operate a four stoke motor. I was thinking of a piped Rossi 60 wieghing 21 ounces without exhaust system, any thoughts on this? Mike
Mystic6 12-29-2002 09:40 PM
GP ultimate bipe
I'm currently building a GP Ultimate (my first build). I plan on powering mine with an OS 46FX. From everything I've read, I gather that most people favor more power than this, but I'm not looking to hover or do any wild aerobatics. The 46 is rated as 1.62bhp, the Rossi looks like 2.5. I would think that'd be enough - that's comparable to an OS 120FS.
Also, I have read that these kits do build heavy. I expect to have to add weight to the nose.
I'll be interested to see other replies as well.
Spicoli 12-30-2002 01:06 AM
GP ultimate bipe
Mystic6-you are wasting time worrying about horsepower figures they dont mean much.
There is no way you can compare a 46 2 stroke to a 120 4 stroke.
Edgar Perez 12-30-2002 02:45 AM
GP ultimate bipe
Go 4-stroke. It's not hard to learn and you will appreciate the thrust a bigger diameter prop will give your ultimate.
A have one with a Saito .91.
Good luck,
Spicoli 12-30-2002 04:41 AM
GP ultimate bipe
guaraguao-I was thinking about putting a Saito 91 in mine.Did you have to move the batteries from the stock location to get it to balance?Did you have to add lead?What does yours weigh with the 91?
Edgar Perez 12-30-2002 01:18 PM
GP ultimate bipe
Yes, I have to put behind the last former in the wing saddle to balance. With a 5cell 1100 battery and tru-turn spinner, it goes for 6 pounds and 9 ounces. No lead required.
A great flier (best maneuver: inverted flat spin)
Good luck
kirknik 01-03-2003 07:43 PM
Gp Ultimate and FX 46
1 Attachment(s)
Mystic. I built a GP Ultimate last summer, powered with an FX46. 11x5 APC prop.
Tons of power. Wont hover, at least not for me, but all else is great. Flies great. Watch the elevator throws. I set mine by the recommended amounts in the manual and almost lost it on first take off. Straight up, straight down and up just in time to bend the landing gear but saved the plane.
Did have a lot of engine problems that turned out to be overheating and subsequent leaning out. Ended up covering the front hole in the cowling opposite the cylinder. Much better after that. Go figure
kirknik 01-03-2003 07:47 PM
GP ultimate bipe
1 Attachment(s)
front shot
GarySS 01-03-2003 11:09 PM
GP ultimate bipe
Dang, the front shot doesn't work. I'd like to see it!!
kirknik 01-04-2003 12:45 AM
trying again
1 Attachment(s)
lets try this again.
GarySS 01-06-2003 04:42 PM
GP ultimate bipe
Humm,..... must be a problem with the front shot set up photo.
mrisis 01-06-2003 05:31 PM
GP ultimate bipe
The thumbnail isnt working but click for full size, works for me
Spicoli 01-06-2003 06:40 PM
GP ultimate bipe
The plans call for 1degree upthrust.I have built lots of planes and have not come across any needing upthrust
Is the upthrust necessary?
kirknik 01-06-2003 08:54 PM
up thrust
I built mine as per the instructions and it flies great, so if 1 degree up thrust is called for i'd put it in.
I have noticed a tendency for the plane to flare at very slow speed. It's very gentle and predictable but I have to put a little down elevator in when landing. I think this is a wing incedence problem and was making small changes to the top wing but ran out of summer before getting it nailed down for sure.
