what should i do?
i have a YT International-adrenaline 120, i just maidened it today, had a bit of fun but the screws on the cowl came off, only one of them was holding on the canopy at the end. i did use fuel tubing but still it comes off? any ideas on what to do?
thanks |
RE: what should i do?
maybe drop some thin ca in the holes (take the screws and cowl off first ;) ). Let it harden. Screw the screws back. Undo them again. CA the holes again (2nd time), let dry.
Should be good to go. |
Take some pieces of nyrod (the yellow part of Gold-N-Rod or Lazer rod ) about 1/2" long and CA them into the fuselage. When the CA has dried put your screws in. The screws are relatively easy to get in and out, but will not vibrate loose in the air.
A big "DITTO" to what Campy said
