prop
does anyone know where i can get a 3 bladed pusher prop in 10X6 to 10X8or9 size
RE: prop
What size engine is this for ? You are aware that going from 2 to 3 blade, you drop one dia. size and up one in pitch ?
Only ones I know of anywhere close are the MAS and Windsor 9x7 for a 40 size. |
RE: prop
Upping 1" in pitch will put a greater load on the engine. In most cases, one needs to "reduce" the pitch by 1 or even 2 in addition to dropping the diameter.
RE: prop
Hobby Lobby sells Graupner Pusher props in the sizes you are looking for!
http://www.hobby-lobby.com/grprop.htm Doug |
RE: prop
Doug,
On their site, I didn't notice any 3 blade pushers that cpbpilot requested. |
RE: prop
My bad! I didn't read close enough.
Good luck cpbpilot! Doug |
