CA hinges?
Are these hinges any good? I have been seeing them supplied in some of the Arfs I've been building, but I have always liked the more secure heavier hinged dubro or GP style. They look like they may crack or fatigue after a little use. To be honest, they scare the hell out of me.
CA hinges?
Do a search on "CA hinges". There was quite a quite long thread relating to them.
CA hinges
I've used CA hinges on over 30 planes I've built for myself, and others. I havent had one fail yet. I actually prefer them over the Dubro hinges. They are much easier to use, you dont need to worry about aligning them, and they hold glue very well. Just stick them in the slot, and run a few drops of CA on them, Presto! They dont get brittle, and they actually hold stronger and longer than Dubro hinges. I would recommend them for any planes .25-1.80 size. Monokote hinges work best for small planes.
Good Luck! |
CA hinges?
I actually installed my first set of CA hinges on the ailerons of a Thunder Tiger Lazy Tiger 51 last night. The other ARF's I have built all had pinned hinges. The CA hinges were a piece of cake. I think I may have used just a little too much CA on the first few just because I was being over-cautious, but they turned out fine. In my opinion they were much faster than installing pinned hinges.
Mike |
CA hinges?
<I think I may have used just a little too much CA on the first few>
Never had that problem..I always go back over 2 or 3 times.....till the CA quits wicking in. |
Don't re-glue!!!
The thing to remember is that once you have glued in a CA hinge and allowed the CA to harden before flexing - which establishes the hinge line - Do NOT ever apply more glue to the hinge!!!
When the glue hardens and you flex the control surface you create a crease or bend where the hinge will flex - If you put more glue on after that it will fill that crease and will probably lead to premature failure of the hinge! It only takes a little glue wicked in from both sides to glue them in. The best thing that I have found is to get one of those real small pointy glue bottle ends to use for getting the glue right to the hinge and not all over the wing..... And to really make them easy to install - get the Great Planes SLot Machine. Makes really nice pockets for the hinges that fit perfect every time! |
CA hinges?
I've used these on several planes. GreatPlanes includes them in several of thier kits. I built my first EXTRA300, and used these hinges just as instructed. The plane met an unfortunate demise, and the only thing left intact was...you guessed it....the hinge-lines. I inspected the wreckage thoroughly, and not one of these hinges let loose. That's right, totalled airplane, and the only thing surviving was hinges, and several splinters of wood.
These hinges are very strong if installed properly. I've since built another EXTRA, and did'nt hesitate to use the hinges again. They are very simple to install, to simple for some I guess. :D Good luck. :) |
CA hinges?
I use CA hinges, however I use epoxy instead of CA. Never had one fail. Daz...
CA hinges?
Don't reglue!!
I guess I should have said I go back and reapply CA 2 or 3 times in the same session. Once the CA has dried/cured I don't reglue. But I'm sure there is enough CA! On slots that were cut by anything other than a #11 blade I use gapfilling CA for the third and final application of the session. |
CA hinges?
Thanks guys, had my doubts about them. I will go ahead and install them in the Taylorcraft.
CA hinges?
I have only had 1 CA hinge fail me and it was one of those paper thin ones by who know's what company. I love them nice thick CA hinges by Great Planes!! And do not just glue half of them in at a time while the aileron is not attached to the wing, have everything hooked up before gluing!!!
CA hinges?
My experience with CA hinges is also very posative! i've used them up through 60 size planes with no problem ... They work best if the slot is not too big , cut it carefully!! you can easily reenforce them too by drilling a1/16 hole through the middle of
each side AFTER it is glued in place and ca a round toothpick through the hole and cut off flush! gene2586 |
CA hinges?
If you have any doubts glue one in a piece of balsa and try to pull it out...................
Re: CA hinges?
Originally posted by chook Are these hinges any good? |
Crayon!
Don't forget to draw a crayon line down the middle of both sides of the hinge!
The wax will indicate the center line of the hinge during assembly and will repel the CA to keep the hinge flexible. The hinged surface will be much more flexible with this method, and there is no danger of hinge cracking. If you're clever, you can pick a color of crayon that helps to hide the hinge. |
| All times are GMT -8. The time now is 06:44 AM. |
