Radio setup with dual elevator and aileron
This is my first plane with dual elevators. I have a futaba 9c radio and i'm not sure which channels on the reciever to use for the elevators and which ones to use for the ailerons. The book is kinda confusing. The plane is a showtime 50. Any suggestions?
RE: Radio setup with dual elevator and aileron
The 9c, if using the ailevator function, uses channel 2 & 8. Use differential wing, on acro & channels 1 & 7 are ailerons.
Safe Flying! |
On an 8U Futaba I used 1 and 6 for ailerons and turned Flaperon on and 2 and 7 for elevator.
Bill |
you guys would be so much better with JR any channel mixing works wonders.
ORIGINAL: Flying freak you guys would be so much better with JR any channel mixing works wonders. and your post has worth how?? to the original poster... simply turn on flaparon and ailevator and use the channels mentioned above |
