Wheel Problems
Hi there i have just got my kyosho up and running but suddenly now. When i start the engine the wheels rotate once startede the wheels slowly spin if of the floor if you place it on the floor the engine dies. You have to give it some revs for it to go what is wrong thanks alot JK
RE: Wheel Problems
Are you talking about a CAR?
( in an airplane forum..... ) |
RE: Wheel Problems
I know NOTHING about cars but it sounds like the clutch is not unconecting if ou will at idle the wheels spin and when you put it on the ground the wheels load the engine because it is at idle it can not take it drops the rpmand it dies..
| All times are GMT -8. The time now is 05:56 PM. |
