RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Masking off Dope (https://www.rcuniverse.com/forum/questions-answers-154/5259728-masking-off-dope.html)
Canuck1 01-13-2007 05:41 PM
Masking off Dope
How long should I wait before I mask, between different colours of dope. I am currently using buterate colours, and I am wondering when it is safe to proceed with my next colour. Also I have heard, or read somewhere that after it is masked, I should go over the masking edge with clear just to seal the tape and prevent bleeding? If this is the case do I need to spray that, or is brushing good enough. Last question, how long can I leave the masking on before I actually spray, and how long should I leave the masking on, after spraying.
Craig.
Campy 01-13-2007 06:56 PM
RE: Masking off Dope
ORIGINAL: Canuck1
>To be safe, I suggest 24 hours for the dope to dry adequately for masking. I
>VERY STRONGLY suggest useing 3M "60 Day Safe Release" masking tape. This
>tape is blue in color, has a paper appearance and if you look at the side of the
>wrapper you will see an "adhesive rateing". You want a "2dot" adhesive rateing.
>My exparience has shown this particular tape adheres reasonabley well, yet will
>NORMALLY not pull up fresh paint underneath it.
>You can use clear, or (my preference) is the color that is under the tape. The
>purpose of this is to prevent "bleed under". To spray or to brush - How did you
>apply the initial coat(s) of dope and how large an area will you painting ? If you
>want a top quality job you need to spray the paint unless you are doing some
>very fine detail painting. The brush strokes WILL show on the final product
>99.9% of the time, especially on large areas.
>I try not to have the tape on the plane for more than 3 hours before painting
>and I remove the tape as soon as the paint is "DRY TO THE TOUCH". You need
>to be careful when removing the tape. The paint forms a skin that is dry to the
>touch, HOWEVER anything beyond a very light pressure on the paint can leave
>a mark. Ideally, you want to remove the tape before the paint has completely
>dried.
Craig.
LesUyeda 01-14-2007 10:21 AM
I leave my tape on until the object is dry enough to handle easily. Remember to pull the tape back on itself, and not perpendicular to the surface.
Les
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
