ENYA MANUALS & PROPS
Is there any place to procure operator manuals for the Enya 90 4C or other engines? I have a 90 4C which needs some parts and tuning and I have no stats to start with. Also does anyone know what size props are recommended for the 90 4C? Would appreciate any info available. Will be happy to pay for copies and shipping, etc for the information.
Also have the Enya 60 4C (need a carburator due to ground contact damage). |
RE: ENYA MANUALS & PROPS
Hi!
There is nothing special about the Enya .90 four stroke...Use a 14x6 or 15x4 APC prop like on any other .90 fourstroke and ofcourse 5-15% nitro fuel and an OS F plug and you'll be just fine! |
Thanks Jaka, finally found out, as you said, to begin with a 14x6 and go from there on the prop --- However, on the Enya 90(at least this one!) the prop shaft is only 5/8 inch long, not long enough for a prop, prop washer and even a prop nut of any kind. When measuring prop shafts on Saito, OS, etc the shaft is over an inch long with plenty of room for a heavy nut or what ever is needed. The nut(with a sleeve) and prop washer that came with the motor will work, but I need larger nut in order to use an electric started well.
Any One with any info on this please? |
1 Attachment(s)
HDB, Enyas take a special nut. HDB, I re-read your post and realize you aready have this nut.
Thanks for the info TimC. Yep, that is exactly like the one on my 90 ! Now - what do you do if you want to use a larger acorn nut for the electric starter ? I guess you forget it and use a smaller rubber adapter on the starter. I have it installed in a F6F Hellcat and wanted it to look correct, but will use it as is and get it in the air. Thanks much for clarifying the question.
MRC has spares listed on their web page. They might be able to supply you with the manual.
http://www.modelrectifier.com/ |
