RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Retracts Hangar 9 Miss America (https://www.rcuniverse.com/forum/questions-answers-154/5448663-retracts-hangar-9-miss-america.html)
PARATROOPER 02-20-2007 06:13 PM
I am having problems with my retracts on my hangar 9 mustang Miss America Iam using a futaba retract servo S136G AND it appears to be binding and not enough power to pull them up all the way.Can anyone help me out with this problem.
PARATROOPER
BarracudaHockey 02-21-2007 03:21 PM
RE: Retracts Hangar 9 Miss America
You probably have them set up wrong but those retracts are junk, I replaced mine with a set from http://www.franktiano.com
The proper way to setup a retract servo (i have the same one and its fine for that model) is to measure how far the push rod moves thats attached to the gear mechanisim and slides in and out to push or pull the retract.
Then take a blank servo wheel and drill 2 holes for the rods or keepers 180 degrees apart and the same distance between the holes that you got from measuring the throw of the control rod. That should give you lock to lock movement without binding.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
