RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   burning out motor (https://www.rcuniverse.com/forum/questions-answers-154/5575099-burning-out-motor.html)
twinz3950 03-17-2007 12:43 PM
burning out motor
i have a e-flight p 47 thunderbolt arf kit. i have used every part the the manual recommened but the battery. It says to use a 3 cell 11.1v 2100 mah battery. i already had a parzone 3 cell 2200mah battery and decided to use it. i have burnt out two stock brushed mottors and one speed controll. i am using a e-flight 20 amp brushed speed control. why are my motors burning out. is it the battery or speed control.
Campy 03-17-2007 10:00 PM
RE: burning out motor
Sounds like the ESC is the culprit. Have you programmed the ESC correctly - number and type of cells, brake, timing, etc. ?
KidVermin 03-17-2007 10:29 PM
This might be answered better in the electric discussion section.
I'm surprised the instructions say 11.1 volts into a 7 volt motor. I've been using an 8 cell 2,000 mah NiMh 9.6 packs for my 400 and 480 motors. Advancing the timing on the 6v 400 or 7v 480 motor, the 9.6v makes it scream but cuts the life in half. Your 3c pack works much better on the brushless system. Is your pack the 10, 12, 15 or 20c dump rate ?
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
